try this.
SELECT : start -control panel(change it to classic view if you dont have it already like that)-device manager-modems- then disable all modem drivers except for pda net. that should be the only one there.-reboot-try it again.
mine did the same shizz. It worked when i first installed and used, then when i tried logging back on it gave me that.
A friend of mine has a moment and he wants to tether so I downloaded PDA.net but his computer won't recognize the moment it says it can't find the driver. Went to June fabrics but no luck. How can I get his computer to recognize the phone. Thx.
