Root PDF ebooks
I upgraded my Nook Color to Jelly Bean on SD card. I love it.
But I can't get PDF library books to the Nook. I have ADE on my laptop but it does not recognize my rooted Nook Color when I connect it. I'm able to get the book to ADE but as ADE does not recognize the Nook I can't drag and drop my book to it so I can read it.
If I boot the Nook to stock, ADE recognizes the Nook.
So does anyone have any ideas how to load PDF books to the rooted Nook to be able to read them?
I use WiFi File Transfer Pro to transfer files from my computer to and from my Nook. It works with CM7 and does not require any other apps/software. Only downside is that you initiate the transfers from your computer and not the Nook.
Overdrive does not open PDF books. The PDF library books need to be downloaded to Adobe Digital Editions. From there you need to drag and drop to the Nook Color.
Anyway I have the answer thanks to Leapinlar at XDA Developers. You need to update CM10 to 04142013 nightly. Once installed, enable USB mass storage. This was something that did not work in previous versions. Make sure USB debugging is OFF. Open ADE, plug in NC. It should now show up in ADE. Drag and drop PDF library book into NC. Works great!!!!!
