Root Pe4.2 bug??
biggdogg
For the past two weeks I have had a voicemail notification icon in the notification bar and I cannot get rid of it! It is driving me insane, LOL. Is anyone else having this problem? I tried everything short of reflashing the ROM. Im not even sure if it is a ROM bug. I even went into my voicemail settings through calling *86 and turned the message indicator off manually. I rebooted, cleared caches, checked settings, you name it I tried it. Anyone else having this problem?
Sorry Biggdogg, I've never seen this issue with voice mail or any other notification, and I've been running PEv4.2 for weeks now.
Got another problem now too. My favorites list from my contacts somehow ended up on the Black list. every number! I been missing calls for over a week and never knew it!!!!
wow...I just loaded up this ROM and I can not say anything bad about it. I did get rid of LP and put ADW on it because the redraws on LP were driving me nuts.
BTW, Have you tried the clear button on the notification bar. I have not yet had a missed call or voice msg, so I do not know
Yea I tried everything, it could just be my phone. YES, THIS ROM IS SICK FAST AND SMOOTHER THAN A BABIES BOTTOM!
biggdogg, are you using the new call screen that requires you to touch the menu to hang up, dialpad, etc.? If so, and you're using the key on the top right to hang up, that button actually sends any call you hang up on using it to the blacklist. The actual hang up button is the one below that one. To prevent that, go into Settings>Call settings, scroll down and check In-call touch UI. That will get you back to the normal call screen and no more calls will be sent to the blacklist unless you want them there.
Thanks for the reply. Unfortunately I dont think that was the problem. One of the reasons I like this ROM so much is the fact I could set the phone to vibrate on hangup and not have to hit any buttons to end the call, I would just let the other person hang up and then I wait for it to vibrate and then I put it in the case. I have seen the button you speak of , it looks like a receiver thats cracked in half. I have never used this button. I also have a message notification icon stuck in the notification bar that wont go away no matter what, I have another thread for that! LOL
HaHa, Weird! I posted that question on Droid Forums.net and you answered it here, lol, man I was confused for a minute there, lol
