Peep is not auto syncing. When I open the application, it then will sync. I have the update frequency set to every 1 hour. I have notifications turned on. How do I fix Peep.
I did play around with Friendstream, but I disabled it and took it off my home screen.
I was having this same problem. The widget wouldn't update at the interval I had it set to. Also, I was getting duplicate notifications of mentions even after I read them. Installed the Android Twitter client and have been happy ever since.
