Root Pendo pad 7 jellybean help please
TJBlueyes
I have trouble with my Pendo Pad 7" with comes with 1 mobile market for apps which is giving me trouble with those that need google play. Is there anyway to root and use gapps with this.
Tablet model: PNDPP41DG7BLK
Any help will be appreciated.
(Note: i have tried to use the jellybean google play apk but it just keeps closing.)
Now the tablet above has been rooted another problem has arisen. Does anybody know restore the primary partition on the tablet when it has been lost?
I use another tablet now so I haven't given this much thought (or stumped as to know what I can do about it). Any suggestions?
Any luck with this, mine (Tablet model: PNDPP41DG7BLK) is stuck at the pendo boot screen, can`t access properly with adb. all drivers installed, I do have backup files boot.img/bootloader.img/data.tgz/recovery.img/system.tgz not sure on how to convert to img file to flash.
I just bought a 7 inch Pendo Pad at Target (in Australia) for my daughter. It cost $99 and seemed fine... until we tried to install anything on it. It only has some third party app store called "1 Mobile Market" on it. Unbelievably, this is an Android tablet that does not have access to Google Play. How useless!
We took it back and exchanged it for a Thomson 7 inch tablet that seemed to be every bit as good, had Google Play, and was even a bit cheaper, so we had enough left over to buy a case for it too.
Its a worrying trend that Android devices are being sold without access to the genuine Android market, which is Google Play.
Beware people. Only buy devices that come with Google Play or you'll be stuck with a lemon.
Anthony.
