People View Problems
jprow507
So I recently started using the Favorites/People widget and when I added a contact to the "Favorites" group so they are displayed in the widget, it removed that contact from the "All" category of the People view. I then went back to the contact an unchecked favorite, leaving the contact in the original Family group and they still didn't show up in the "All" people view.
It seems that if you go into any contact in People and Edit and change their group (or simply uncheck then recheck their group), they disappear from the All view and are only visible thereafter in the corresponding group view. How do I get them back into the All view?
UPDATE: I figured out that in order for people to show on the "All" view they need to be in the VIP group.... hopefully this info helps someone else who ends up with this problem.
