FlatEarth
Hey guys!
I am looking to permanently disable WIFI capability for my Samsung Android Core phone.
While doing some research on how to make this happen I found two methods, both of which I tried and neither worked.
Method 1:
The first method was to root the phone, and in the systems folder/lib/modules, find and delete the file "bcmdhd.ko". This file didn't exist on my phone.
Method 2:
The second method was to go into the systems folder and open build.prop and remove the following lines:
BUT, these lines don't even exist in my build.prop folder!
Now that I've tried both methods and neither worked, I am unsure what to do next, and that brings me to androidforums.com to ask you for help. Please let me know what I can do to permanently disable WIFI.
Thanks so much!
PS - Just in case it helps, here are the contents of my build.prop file:
Method 1:
Method 2:
Code:
wifi.interface=
wifi.supplicant_scan_interval=
Thanks so much!
Code:
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=KOT49H
ro.build.display.id=KOT49H.G386WVLU1ANJ2
ro.build.version.incremental=G386WVLU1ANJ2
ro.build.version.sdk=19
ro.build.version.codename=REL
ro.build.version.release=4.4.2
ro.build.date=Mon Aug 31 20:15:39 KST 2015
ro.build.date.utc=1441019739
ro.build.type=user
ro.build.user=dpi
ro.build.host=SWHD4417
ro.build.tags=release-keys
ro.product.model=SM-G386W
ro.product.brand=samsung
ro.product.name=afyonltevl
ro.product.device=afyonltecan
ro.product.board=MSM8226
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=samsung
ro.product.locale.language=en
ro.product.locale.region=CA
ro.wifi.channels=
ro.board.platform=msm8226
# ro.build.product is obsolete; use ro.product.device
ro.build.product=afyonltecan
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=afyonltevl-user 4.4.2 KOT49H G386WVLU1ANJ2 release-keys
ro.build.fingerprint=samsung/afyonltevl/afyonltecan:4.4.2/KOT49H/G386WVLU1ANJ2:user/release-keys
ro.build.characteristics=bmc
# Samsung Specific Properties
ro.build.PDA=G386WVLU1ANJ2
ro.build.hidden_ver=G386WVLU1ANJ2
ro.build.changelist=2988301
ro.product_ship=true
ro.chipname=MSM8926
ro.config.rm_preload_enabled=0
ro.build.knox.container=
persist.sys.storage_preload=1
# end build properties
# from device/samsung/afyonltecan/system.prop
# system.prop for msm8974
rild.libpath=/system/lib/libsec-ril.so
rild.libargs=-d /dev/smd0
persist.rild.nitz_plmn=
persist.rild.nitz_long_ons_0=
persist.rild.nitz_long_ons_1=
persist.rild.nitz_long_ons_2=
persist.rild.nitz_long_ons_3=
persist.rild.nitz_short_ons_0=
persist.rild.nitz_short_ons_1=
persist.rild.nitz_short_ons_2=
persist.rild.nitz_short_ons_3=
ril.subscription.types=NV,RUIM
DEVICE_PROVISIONED=1
# For sys info indication
persist.radio.add_power_save=1
# VoLTE/IMS
persist.radio.calls.on.ims=true
persist.radio.jbims=1
ro.sf.lcd_density=240
debug.sf.hw=1
debug.egl.hw=1
debug.composition.type=c2d
persist.hwc.mdpcomp.enable=true
debug.disable.bwc=1
debug.mdpcomp.logs=0
dalvik.vm.heapsize=36m
dev.pm.dyn_samplingrate=1
persist.demo.hdmirotationlock=false
ro.hdmi.enable=true
tunnel.decode=true
tunnel.audiovideo.decode=true
lpa.decode=false
lpa.use-stagefright=true
persist.speaker.prot.enable=false
qcom.hw.aac.encoder=true
# system props for the cne module
persist.cne.feature=0
#system props for the MM modules
media.stagefright.enable-player=true
media.stagefright.enable-http=true
media.stagefright.enable-aac=true
media.stagefright.enable-qcp=true
media.stagefright.enable-fma2dp=true
media.stagefright.enable-scan=true
mmp.enable.3g2=true
mm.enable.smoothstreaming=true
media.aac_51_output_enabled=true
#37491 is decimal sum of supported codecs in AAL
#codecs: AVI AC3 ASF AAC QCP DTS 3G2 MP2TS
mm.enable.qcom_parser=37491
# VIDC: debug_levels
# 1:ERROR 2:HIGH 4:LOW 0:NOLOGS 7:AllLOGS
vidc.debug.level=1
# system props for the data modules
ro.use_data_netmgrd=true
persist.data.netmgrd.qos.enable=true
ro.data.large_tcp_window_size=true
#system props for time-services
persist.timed.enable=true
# system prop for opengles version
# 196608 is decimal for 0x30000 to report version 3
ro.opengles.version=196608
# System property for cabl
ro.qualcomm.cabl=1
# System props for telephony
# System prop to turn on CdmaLTEPhone always
telephony.lteOnCdmaDevice=0
#Simulate sdcard on /data/media
persist.fuse_sdcard=true
#snapdragon value add features
ro.qc.sdk.audio.ssr=false
##fluencetype can be "fluence" or "fluencepro" or "none"
ro.qc.sdk.audio.fluencetype=none
persist.audio.fluence.voicecall=true
persist.audio.fluence.voicerec=false
persist.audio.fluence.speaker=true
ro.qc.sdk.sensors.gestures=true
ro.qc.sdk.gestures.camera=false
ro.qc.sdk.camera.facialproc=false
#property to enable user to access Google WFD settings.
persist.debug.wfd.enable=1
#property to choose between virtual/external wfd display
persist.sys.wfd.virtual=0
tunnel.audio.encode = true
#use VERY_HIGH_QUALITY for audio resampler
af.resampler.quality=4
# ADDITIONAL_BUILD_PROPERTIES
persist.sys.logkit.ctrlcode=0
keyguard.no_require_sim=true
ro.com.android.dateformat=MM-dd-yyyy
ro.carrier=unknown
ro.com.google.clientidbase=android-samsung
sysprof.activitythread.slowloop=300
sysprof.choreographer.skip=15
sysprof.inputdispatcher.slow=500
sysprof.inputdispatcher.stale=500
ro.vendor.extension_library=/vendor/lib/libqc-opt.so
persist.radio.apm_sim_not_pwdn=1
dalvik.vm.heapstartsize=8m
dalvik.vm.heapgrowthlimit=128m
dalvik.vm.heapsize=512m
dalvik.vm.heaptargetutilization=0.75
dalvik.vm.heapminfree=2m
dalvik.vm.heapmaxfree=8m
ro.build.scafe=capuccino
ro.build.scafe.size=short
ro.build.scafe.shot=single
ro.hdcp2.rx=tz
media.enable-commonsource=true
ro.secwvk=144
ro.securestorage.support=true
ro.sec.fle.encryption=true
ro.error.receiver.default=com.samsung.receiver.error
ro.config.ringtone=Over_the_horizon.ogg
ro.config.notification_sound=S_Whistle.ogg
ro.config.alarm_alert=Morning_flower.ogg
ro.config.media_sound=Media_preview_Touch_the_light.ogg
ro.setupwizard.mode=OPTIONAL
ro.com.google.gmsversion=4.4_r4
persist.sys.dalvik.vm.lib=libdvm.so
ro.build.selinux=1
ro.kernel.qemu=0
ro.config.tima=1
ro.config.timaversion=3.0
ro.config.knox=v30
net.bt.name=Android
dalvik.vm.stack-trace-file=/data/anr/traces.txt
ro.qc.sdk.izat.premium_enabled=0
ro.qc.sdk.izat.service_mask=0x0
persist.gps.qc_nlp_in_use=1
ro.gps.agps_provider=1
