You need to use something like Root Explorer and delete the apps from the syste/app. It is highly recommended not to do that as if you do that there will be no way to restore your Note to factory default without flashing a ROM.
You would be better off using Titanium Backup. Back everything up, freeze whatever you do not want to run. Alternatively backup and then delete the app, but keep the backup.
