Personalize > Folder - ?????
3dyoni
I want to know what everyone else thinks about this. The folder should be quite useful to organise different apps, and take up less space on the 7 home screens (much like the iPhone 4 folders). But as you cant change the name, is it of any use to anyone?
Of course you can change the name. Open the folder and long press the title (where it says "folder") to rename.
To change a Android Folder name you open the folder and then long press the grey bar at the top where the name is and voila :p
The feature is so obscure I wonder how many other Android easter eggs are waiting to be found.
Well I never realised that. I've had a folder with all my apps in named folder for ages.
Thanks for the tip
