I would like to install this but I think the directions might be a little too vague for me.
- Copy "phiremod-V6.zip" to the root of your SD
- Boot into the latest ClockworkMod Recovery for nook from Rom Manager
- Format SYSTEM and then DATA
- Flash phiremod (should take about 5 minutes)
- Once complete, reboot
Do I need to remove the SD card from my nook and do step 1 via a card reader or can I just hook my Nook up to my pc and do it?
For step 2 do I just open Rom Manager and then click "Reboot into Recovery?"
How do you do the formatting? How do you flash the rom?
If this is self evident then I apologize but I would rather feel comfortable ahead of time rather than not know how to do something in the middle of it.
Edit: Actually, can I just use these directions?
How To: Load a Custom ROM on the Nook Color | TheUnlockr
Except I WOULD wipe the data, correct?
Ok, I am in the Recovery Menu right now. I do not see formatting. Is that "wipe data/factory reset?"
What about wipe cache partition.
NM, you have to go into Mounts and Storage.
Still wonder if I need to wipe data though.
I've been IT for 9 years.
Power on with n button pressed is supposed to work but mine is broken. I have an idea of what to do tho.
I'm have never used a phiremod rom. Is there much of a difference between this and regular cm7? I read some of the post over at the xda forums and it looked like they just added a overclock kernel, i didn't see much difference but i will install this tomorrow just to see what its like.
This doesn't work with me either - do you know what the issue is? Powering on & off 8 times whenever I need to go into recovery is annoying!
