samichelle
Hi everyone, my motorola milestone auto restart once in a while. Can someone pls let me know. Thanks.
Actually, an 'auto restart' could be quite useful, IF it was controlled and scheduled, in order to keep the phone functioning at max capacity and clear the memory. Is there an app that can do this in a scheduled manner, or does an app exist like "Slide to Shutdown (winmo)" that will restart an Android device in stead of just turning it off? Thanks!![]()
I'm sure someone will comment soon enough on what ones there are to choose from
Yes there is a app for that. Can't remember what ones there are, and I'm too lazy to search googleI'm sure someone will comment soon enough on what ones there are to choose from
I Googled and it only seemed to populate more questions like mine and how to remotely shut down your Android phone if stolen
Power Off is an uato-restart app in the Market - root users only.
Thanks for the help guys! Hopefully a root will surface soon.Everytime when I wanna update my phone, it says I got the latest one already. I got apps like BatteryTime Lite, AndExplorer, Ringdroid & some games. Do u know what apps will cause it to reboot? What I meant offline is it reboot & ask for pin(common thing when u turn on the phone) but sometimes it just reboot & never ask for pin.Have you tried to update your phone recently? A new update came out just the other day. What apps do you have installed? If your not too attached to your settings and stock your sbf file and start over does it still happen? I am too also new to Android and smart phones but have come along pretty quick with the help of guides and reading on forums. When you say offline do you mean the phone is just off? So either it is a update you need to do or you need to check over the apps you have installed. One of them is most likely causing it to reboot.
By the way...what's the meaning of rooted anyway?? Sorry guys...I'm still new here.
So, what would u recommend me to do? Any good suggestion? Would it be better if I update to 2.2 firmware? How can it be done?
I wanna do something else. What do u think about TelusMilestone idea? Or do u have a better one? Pls teach me...step by step if possible because I'm not too good at it. Thanks.1. There is no 2.2 ROM for the Milestone.
2. What do you want to do? Do you want to reboot your phone or do something else?
hi !! i have a motorola milestone ...and suddenly it's started to auto restart without stopping until it appears some kind of boot menu on the screen ....it says : ""bootloader 90.78 .....code corrupt....battery ok ....cannot program """ can you help me please to fix this problemHave you tried to update your phone recently? A new update came out just the other day. What apps do you have installed? If your not too attached to your settings and stock your sbf file and start over does it still happen? I am too also new to Android and smart phones but have come along pretty quick with the help of guides and reading on forums. When you say offline do you mean the phone is just off? So either it is a update you need to do or you need to check over the apps you have installed. One of them is most likely causing it to reboot.
