Hello, since yesterday morning,
after testing an app with eclipse on my phone, I plug it into USB, I accidentally clicked on scan and repair disk "Note" under win 7 .. said some defective files have been recovered ..
After a few mms sent with my Galaxy Note, some time later, not at home : it hangs on a black screen ( shutdown ), then crashes every startup after loading applications ( shutdown again, not a restart )...
=> Excepting if my phone is being charged .. that's the only way I can use it currently, annoying ..
I tried aLogcat but the phone crashes when I unplug the usb cable .. the crash-loop disappears when I restart with the usb cable. Then re-appears when I send an sms on battery or execute any application
My phone was rooted in stock 4.0.4, I've put phil recovery, cleaned data cache factory reset put a new rom ( Ultimate_N7000_LT4_JB_4.1.2_v6 )
I don't know what to do with this one, as there's no diagnostics tools, not any response on other forums .. Do you have any ideas?
Thanks in advance :smokingsomb:
Here is a logcat which recorded something before the crash .. nothing in /data/dontpanic/
alogcat before crashe - dumpstate_app_error - traces.txt
