Help Phone battery not changing
Kross2
My battery meter seems to be stuck at 100%, it hasn't changed for hours. Is there anything I can do to fix this?
It may go back with a reboot, if not just turn it off, pull out the battery for 30 seconds, re-install it and power it up again. This issue should have been fixed in the last update, if you've received it already, if not you should get it soon.
