Help Phone Button goes to Call Logs
ml_nelson
When I push the real-mechanical button with the phone-symbol on it, I'm taken to the Call Logs screen.
This is not sensible. I expect to go to either Contacts or to the Dial Pad, but not Call Logs.
Is this configurable in any way?
Mike
Well, u cld just take 1sec and and either press the phone tab on left, or just start dialing...its not isntantanious but it doesn't bother me. You could probably make a custom short cut...but its easy enough, I can't see the problem.
Mike
That's the same way ALL LG phone work.Press it 2 times,and it redials the last dialed number.
JL
Mike
Simple solution. Go to the market and download one of the phone widgets and place it the opening screen. Works great. Simple too.
