phone call recorder
lobe50
Member
Hi
Is there a way to record phone calls on the Droid?
Or do/can you use a market app for this? I searched "call recorder" in the market & there wasn't much and reviews were not great. Anyone know of any other ways?
Thanks
OK, I have been trying out some I have found on the market, but none work :(
So far i have tried DROIDRECORD, and Phone Recorder.
Anyone know of one that works????
Thanks
what does bump and +1 mean?
+1 meaning you would like to know to & BUMP means bumping the post up to the top of the thread -> to make people see -> hence hopefully answer :)
@Joneee & pittcaleb
What about those that don't have Google Voice? {Like me in the UK}:D
@Carl C - well, you could move to someplace with a better climate, say San Diego, CA, USA ;-)
Personally, I do NOT make outgoing calls through Google Voice and only a fraction of my incoming calls come in that way. But it is a slick feature. Do other VOIP-based services offer call recording? Could you use any of those?
PittCaleb
PittCaleb
Well now that you mention it......... lool :D
I don't use Voip services only calls through my mobile {network} at the moment , It looks like were going to have to stick in and wait to see if an Good app comes across or I get GV :rolleyes:
Thank you anyway guys! :p
I'm looking for a phone recorder app also. Google voice recording won't cut it cause I want to be able to record my outgong calls, not just incoming from Google voice.
if you are a google voice customer, you can configure all outgoing calls to go through google voice if you want. people dial me inbound on my GV number, so dialing out with GV is great for me.
PittCaleb
I am an app downloading/installing/testing FREAK. I have searched high & low, and I haven't been able to find an app on the market yet that can record a call. This is the only feature that I feel is "missing" on my DROID. :o
The last I heard was that GoogleVoice only lets you record incoming calls.
I have yet to succeed on getting the outgoing to work (if I am missing some stupid tiny bit, is it just that I have to start the calls with Google Voice to use the "4" to record?).
In regards to recording calls, I have used one or two apps (one being vrecorder) where when I set it to record the call, it states that this function has been disabled by the phone itself. I cannot find the information before, but I ran across a post about that the Droid will not let you record calls.
I have no idea why, but I think we need a firmware/update fix first before we worry about an application to record the calls without Google Voice.
Bump Bump
I have searched high and low & cannot figure out how to record. Would rooting the droid allow access to recording phone conversations?
It is kinda lame that there is no real option (aside from GV) to record calls in progress, even my old LG dumbphone had this feature. It comes in real handy when you're calling a business and want to end service or make changes, then you both have a copy of the conversation for proof. Just make sure you tell them up front so everything is legal.. blah blah
All someone really needs to do is take a quality recording app and hack it so it includes the speaker. Then you could include recordings in your recordings. Joe would have a tiny mixing studio in his hand!
I installed vRecorder on my Droid, and when I ask it to record a call, it states "This application is Android 2.0 compatible but the Droid artifically disables incall recording".
Makes me think there is a firmware or other switch specifically in the Droid itself that is causing this problem.
I would love to know if anyone finds the fix...especially if it does not involve rooting as I just do not have the time to make sure it is done correctly and thoroughly currently :p
I would imagine it is disabled because it is illegal to record the call unless the other party consents and the great majority of people who use this WON"T be asking for consent before recording a convo. It is a serious charge to do this, my old boss almost got sent to prison for doing it about a year ago.
I believe that the laws on recording phone calls vary by state. I used to work for the state of Iowa and our legal department explained it that in Iowa, you could record a call as long as one party consents to being recorded.
Here is something I found on it.
The U.S. federal law allows recording of phone calls and other electronic communications with the consent of at least one party to the call. A majority of the states and territories have adopted wiretapping statutes based on the federal law, although most have also extended the law to cover in-person conversations. 38 states and the D.C. permit recording telephone conversations to which they are a party without informing the other parties that they are doing so.
12 states require, under most circumstances, the consent of all parties to a conversation. Those jurisdictions are California, Connecticut, Florida, Illinois, Maryland, Massachusetts, Michigan, Montana, Nevada, New Hampshire, Pennsylvania and Washington.
It is illegal under all jurisdictions to record calls in which one is not a party.
While laws do vary from state to state, in most areas there are exceptions. For example, if you have a Restraining Order against someone, then you can record any and all violations of that order without notifing the caller (check your local laws). Victims of domestic violence use these recordings to prove harassment and threats.
Disabling the recorder because it might be used unlawfully is just sad. The GPS, the camera, and the phone itself could all be used in illegal ways.
I would just like to have recording capabilities to be able to take "notes" at times when I can't write it down. Having the app announce that recording has started/stopped covers the legality.
There's an app called PowerCall by mgeek that would've been perfect for this.
Problem is it was removed from the market and I can't seem to find any info on it from a trusted source.
I don't care so much about recording the call, I just want to take notes that can be associated with the caller.
Speech to text covers the hands free part
