victek
I recently updated the firmware in my home router and now my Dinc2 cannot connect to the wifi. More exactly it sees and connects to the network, but then can't receive an IP address using DHCP. I tried an app called Wifi Fixer, but it didn't help. If I change the network settings in the phone to "static IP" and input valid numbers for my network then it connects no problem. I also have a laptop and it connects using DHCP so I don't believe the firmware update failed, but obviously something changed. Using a static IP is inconvenient since I need to remember to disable it when connecting elsewhere - any suggests as to how to fix this will be appreciated.
