Phone change. please help
Amylee3130
HI people
ive dropped my phone and smashed it...i was going to try and fix it myself but dont wanma riak damaging the lcd so i can get it replaced through my insurance...but as ive rooted i will need to back up everything...then im guessin save back up to comp or is there another way...so i when i get other phone i can just reroot it and then restore my back up for the kernal and everything. please help....ps i need help to undo root and counter so they dont know ove modified it.
thanks in advance. my phone will be swapped tomorro so need to do it asap xxx
Hi amylee, can you go back to the forum where you got the root exploit and flash a stock rom? That's what you need to do, Flash back to stock. You can back up any pics music etc on your pc.
Apps you have can simply be re-downloaded from the play store after you get the new phone.
