The light sensor is in the right side of the speaker screen. If you are right handed and hold the phone low on your ear (i.e., the top left corner of the phone is touching your ear), then the light sensor is uncovered and the screen will be on. Try holding it where the light sensor is covered by your ear (so your ear is closer to the top right corner). I did this and haven't had the problem anymore.
