grizmixstir
This is my second LG Velvet (warranty) that does this. It will enter DND mode as scheduled but randomly doesn't exit dnd about half the time.
you can try a factory reset. but if that does not work, than i do not know what else you can do other than to either get used to it or try a different phone. don't expect much from LG though as they are not making phones any more.This is my second LG Velvet (warranty) that does this. It will enter DND mode as scheduled but randomly doesn't exit dnd about half the time.
have you tried a hard reset instead of a factory reset?Thanks for the info folks. I've tried restarting and resetting to no avail. I've also tried safe mode and that also did not help. BTW it is running android 11 with current updates. I wish I knew that LG was getting out of the phone business, if so I'd have purchased a different phone. Oh well, hindsight is 20/20...
