Help Phone doesnt turn on
[/U]45]take it in to metro/best buy/radioshack whenereever you bought it and they should replace it givin you are in the 30 days
Take it to a CORPORATE metro store they will usely try to fix or just replace regardless on the spot
:D
Is there anyway this problem can be fixed because I have the same problem, but I voided my warranty because I rooted the admire.
