chris98891
Hey guys, this just started happening a couple days ago...my phone freezes ALL THE TIME. As in, i can watch the taskbar move, i can see that things are happening, but i can't input on the touch screen or use the touch buttons.
i have unrevoked forever, s-off, the official 2.2.
i have done a factory reset to get rid of everything. i'm trying to figure out what causes it, but it seems like a big problem with the market. i can't download anything, and if i start clicking on too many things, it will either go to an all black and all white screen, where it seems like its loading, but it ever does, and i lose the ability to drop down the task bar.
if i press the sleep button, it will turn off the screen, and if i try to wake it up, it just lights up the home keys, and i get feedback if i press them but it doesn't do anything.
battery pull, phone boots fine. start doing stuff once it starts, and the phone freezes. it seems like i have to wait 5-10 minutes while the phone boots before i can do anything on it without freezing it, because if i get it running, it will run for awhile.
the phone did start freaking out when i installed setcpu, but i feel like after the factory reset it shouldnt have any effects.
so what do we say, any ideas? thanks for any help in advance!
EDIT: found a new way to freeze it after the factory reset, opening gmail. all white screen like its going to open, and then i just eventually lose the ability to touch the screen. market won't start either.
it seems like its just becoming overloaded very easily, and then freezes.
