Root Phone Frozen!
Tboltfan25
I flashed Das BAMF earlier this evening, and my phone has just suddenly froze, I can't turn off or touch anything on the screen...what do I do?
Should i pull the battery?
Yes, pull the battery. If it freezes again, hold the volume down when hitting power and that will beat you into the hboot where you can get into recovery again. Wipe everything and reflash rom.
Mine is still stable. Just curious, which governor were you using? I'm using InteractiveX at 1.6 GHz.
could be a bad download,could be failed to wipe fully- make sure you wipe data/cache/dalvik cache.
also a word of caution- if using set cpu,dont check the "set on boot" box if you wish to OC over 1.4 :eek:
