Root phone gets stuck syncing when auto sync is enabled, any fix for this?
crimton
Android Expert
i am running captjager 1.6.2 and everything has been running swimmingly up til now. it is set to auto syn every two hours, when it starts to sync and the little loop icon appears in the notification bar it just hangs there....forever or until i cancel sync and resync manually then it will finish the sync. is there a fix for this that anyone knows of? if not i will be switching back to stock, this has become annoying and probably is killing my battery.
