So, I have a Vibrant. The issue all started when I tried to install the 1.2ghz OC rom onto my phone. I had rommanager installed, and attempted to run it off the SD card, but when my phone booted up it had lost my applications, everything.
The problem I'm running into now is that the phone seems to be unable to use its mass storage. Every time I attempt to reinstall an application from the market it says it doesn't have enough memory. Under settings it says "unavailable" for the internal mass storage.
I tried using the volume buttons and power button to enter recovery/dl mode but every time I do I cannot make selections. If I use the power button to try to select it does nothing. In fact the "up" volume button makes it go down, and the other "down" button also doesn't do anything.
Since I have no applications I can't use clockwork recovery, even though I know I have one. Also, Odin is unable to connect to the phone, so I can't reload factory. Kies also doesn't recognize the phone.
It also won't even recognize the SIM card, says it has no reception when it clearly does.
