reverting back to stock, ok power down the phone and download and extract this to your desktop
MetroStockRecovery-SCRIPTS.zip after you done that press and hold vol down, end key and tap power, your phone should be on the white huawei screen and it should stay there, now open the folder that you extracted and run both of these file, first run fastboot-windows you will see a black box come and leave quick, next run metroPCSStock-windows.bat than another black box will pop up and it will do its thing, once it finishes the phone will automatic reboot itself.
Boot to cwm VOLUME ROCKER UP+CALL BUTTON+POWER
USING THE TRACK BALL
go to backup/restore and select restore
