Phone idle using 56% battery
How to make this percentage less? My battery finishes after 22 hours of use everyday.
When was the last time you rebooted? That is what typically fixes the problems my gf's Atrix has. Otherwise, it sounds like you have an app keeping it awake. Though 22 hours of battery life is pretty awesome in my mind.
hi
i am using Task Killer to close open applications. I found a software called JuiceDefender and now the battery is working for about 2 days :)
