Help Phone internal storage getting low
zoetey
Hi,
I'm using a Samsung S 2
Model: GT-I9100G
The Android version: 4.0.3
Baseband: I1900GDXLP6
Build No: IML74KDXLP6
I upgraded from the ver2.x.x to this version 2-3 months ago. It was working fine until recently the internal memory start to increase by itself. I tried to delete the application the memory freed up for few minutes then come back again.
Anyone can help how can i solve this issue? I've moved all the moveable application to the SD storage. There are some applications are not able to be moved remain there.
Please help.....
Read that in some cases, its due to wifi logs that keeps increasing and take up the space. The only solution I read of is to do a factory reset. Could you count the memory space that the apps takes up and compare the readings? Or maybe list the apps you are using. Before doing a factory reset, maybe someone can detect if any apps might be the problem.
Cheers
Thanks Russell, my applications total up is less than 800mb. I did a factory reset and reinstall all the applications, it seem ok now. I'm using wifi more than 3G it will become a nightmare for me. I wonder if S3 having the same issue...
Hi, I'm also having an issue with very low phone storage memory and deleting stuff i don't use often has little or no effect. I use wifi alot, does anyone know where these logs are stored and can they be deleted?
