Root Phone is bricked? Shit. Help?
aovaici
Member
So I installed CM7, have been using it for a while, no issues, have installed a few different roms using recovery, decided to switch to SenseROM, so I downloaded it, copied it to my flash drive, went to Restart --> Recovery and restarted... Just like I have always done when I want to try a new rom...
Stuck on LG Loading Screen.. Wierd, I've used the custom recovery a buncha times, so I pop out the battery, start it again...
Same thing... Stuck on LG Loading Screen... pop out the SD card.. pull battery... start it up again... Same thing...
Popout the SD card.. Hold Back and Vol Down and same thing...
Is there anything else I can try? Help?
Is there some way I can get the phone to stop trying to startup into recovery mode? Since my recovery must be corrupt?
You have said that you have switched roms more than once with no problems. In your description of how you did it this last time if you described each step the way you did it then you did not wipe all data which is a step written in the guide. There are more than a few threads on how to get your phone recovered from the LG screen, how long was it on the LG screen before you pulled the battery? I have heard of boots taking up to ten minutes after installing a rom... Which is unlikely but give it ten minutes and see what happens.
