Root Phone is going crazy?!?!
sx4dude2013
Android Expert
So Ive been running the Liquid Rom for about a week with NO issues.
All of a sudden on a normal day (no new apps or anything) I was experience EXTREME lag.....about 10 sec for my phone to unlock using the pattern lock.
My first thought is maybe my undervolting had started to act up. So I removed the undervolting app. I was still having issues. I did a reboot and was still having problems. It was late so I went to bed....
Today I went to hang up a call and the screen was unresposive, wouldnt do a single thing. The other person disconected so the call finally ended.
Also in typing a text all of a sudden it kept pressing the lettet "J" and wouldnt quit. The phone was going crazy....had to pull the battery.
IDK what it is. I dont wanna wipe data or SBF if i dont have to...
Any ideas what to try first?
are you overclocked at all? sometimes the phone will go in turtle mode if clocked to high. you could try making a backup then clear your data. if the problem is still there then you know something is up with the phone.
Ok. I might try a data wipe if i notice it again.
And i was never over clocked, just undervolted...
Thanks for the advice!!!
