Have you rebooted/pulled the battery? Then clear the cache. Then do a master reset. Do it in this order if each attempt fails.
Wipe Cache-power phone off, hold power and home button in until character appears. Push hard search key-magnifying glass. Use volume buttons to select 'wipe cache data'. Press camera button to select. Reboot phone when done. Master reset uses same steps as above except choose wipe user data. Make sure you backup your contacts, apps, etc.
reset scares me but , thank you
Do you have task killer installed?
It shouldn't. Use backup assitant to backup your contacts. It will delete all your text messages and apps installed, but you can put the contacts back using the assistant-very easy-then goto Market and it will re-download all your apps. Takes about 10 minutes tops. I have done it 5-10 times already.
Do you have it setup to automatically kill apps? If so, I suggest uninstalling ATK and see if it stops the freezing. I used to have ATK with auto kill and it caused all sorts of problems with android 2.2. Needless to say I don't use it anymore.
No it will not erase you sd card. To be on the safe side you can remove it before the reset, but it shouldn't matter. And no it will not roll you back to 2.1.
