Help Phone Keeps Powercycling (HELP!!!)
Not too long ago my droid x would just randomly shut off and restart itself. I didn't think much of it at first until it started doing it about once every day. So I went to Verizon and got the phone replaced (they couldn't find anything wrong with it)
I got the new phone and started to slowly add back the applications that I had on my old phone. At the time I had all the stock apps plus launcher pro, handcent, and beautiful widgets. And then the new phone started doing the same thing as my last one.
I decided to delete each app one by one to try and figure out which one it was. When I thought I had finally deleted the app that was causing it. It goes and does it again. I tried a combination of different apps and still nothing. It seemed that nearly any app that I added that wasn't on the phone when I got it, seemed to affect it.
One thing that I noticed is that often times once it restarts, a text message would come through which is why at first I thought it was Handcent but later when I uninstalled it, it still did that same thing.
Here is a list of all my installed apps and if anyone knows which might be causing it please let me know. Also considered rooting and installing a new rom to see if that would help the issue. Any ideas?
Apps:
Adobe Reader
Angry Birds/Seasons
Battery Indicator
Beautiful Widgets
Bookmarks to SD
Brightness Level
Calendar Pad
Chase
Chrome to Phone
Coupons
Craigsnotification
Dictionary
Dolphin Browser HD
Dropbox
Facebook
Google Goggles
Handcent
Juice Defender
Lookout Mobile Security
Moto Torch LED
Pandora
Pew Pew
REI Snow Report
Ringdroid
Skype/Mobile
Slick Deals Rss Feeds
Springpad
Square
Stopwatch & Timer
Tip Calc
Trapster
TuneIn Radio
Unblock me
Uninstaller
Unit Converter
Can't say for sure, but after my last upgrade to Pandora v1.5.4 it's constantly getting wedged and in need of a forced shutdown (this is on my Hero), to the point where I can't use it any longer.
Are these apps you're listing running on the phone when it resets or simply installed? I wouldn't think a non-running app would have any effect one way or the other.
The only app I have in common with you is Adobe Reader, and I would sure hope that isn't it.
I was wondering if NFS Shift which is a reboot tool could be doing it. I don't game on my phone so thinking I will take that off.
Well I deleted NFS a while back and I deleted launcher pro but less than an hour after getting rid of it my phone restarted itself again. I'm getting to the point where I'm going to just install a custom rom.
