Help phone keypad problem
Hi,
I have a Samsung Galaxy S3 on VZW. Often when I make a call that requires keypad presses (e.g. for menu selection), I touch the keypad icon, but the keypad goes blank when my finger approaches it, then reappears (after a couple of seconds) when I pull my finger away. I have to hang up and start the call again, hoping that the problem will not reoccur, which it does about half the time.
Really aggravating:mad:! Is this a bug?
Thanks,
- bill.
You finger may be casting a shadow on the sensor at the top right of the phone. Try coming in from the bottom and see if you can use it.
