I'm trying Cerberus and finding it won't connect while screen is off, any ideas?
If you want to send commands and other data, then of course the phone has to have some kind of data connection, like 3G, 4G, or WiFi. No app can get around that unless maybe through some dial-up sequence, but I doubt anything like that exists.So with WiFi and 3g off I should still be able to activate phone with correct command via SMS.
This does not work, so starting to loose faith a bit now![]()
But SMS is data so you need a data connection like I wrote above.Actually, for this you can use automateit (free version). Something like:
Trigger: SMS received with text "wifi"
Actions: turn on wifi.
Hi, I'm looking for a basic lost phone locater by sending it an SMS from another phone and receiving its location via GPS. The ones on the market seem to have mixed reviews.
Any ideas?
