randomman123
I am now stuck in bootloader mode (the blackhole of death mode where you cant charge your phone's battery) trying to fix my way back to freedom.
First I tried to sbf to 2.3.32 which did nothing for the phone, followed up by 2.3.34 and same result. After trying to update the firmware, I attempted Stock Recovery mode to factory reset it, but the command gets ignored and goes to bootloader.
Typically after turning on the screen will say the following:
Bootloader
30.04
Err:A5,70,70,001F
MEM_MAP Blank
Service Req'd
Battery OK
OK to Program
Connect USB
Data Cable
The screen for RSD looks like this:
Uploaded with ImageShack.us
Though I don't know if the information presented will do any good, I'm hoping it will lead me in the right direction, hopefully not toward the expensive paperweight one. I will greatly appreciate any help offered!
Bootloader
30.04
Err:A5,70,70,001F
MEM_MAP Blank
Service Req'd
Battery OK
OK to Program
Connect USB
Data Cable
