Help phone memory going silly
t_cole10
hi, one minute i have 24mb left on phone memory the next it says 56mb,but nothings changed.Wondered what could be causing this?
many thanks, Stacie
many thanks, Stacie
That sounds strange, Stacie.
Have you deleted any applications or the data or cache from any applications?
The above can free up memory.
You can also get a different amount of free space if you reboot your phone, but certainly not 30MB difference!
Many thanks for advice. Ive not deleted anything,or touched anything.Its been like this for awhile now,up & down on memory,you think could be faulty?
stacie
Do you use the HTC mail app? It cache's email on memory. If during your period that you set to keep emails for (3 days, 5 days etc) you may have much bigger mail items than other times?
Hi, and thanks for info.I think ive found the problem,ive an app called Appreciate on phone,& everytime i use it,the memory goes up & down.Will have to uninstall,which is a shame as its very good.
Stacie
