You should be able to find an option to move the game to the SD card after its downloaded. Check under settings / manage applicatios, chose application, the "move to SD card"
root ur phone and install rom tool box then under that u wud find tools tab scroll it down u wud get app manager open it and tick apps u want to move on SD CARD and move dem
secondly after doing that scroll down in same menu u wud get configure apps 2 sd card app click on it and tick on SD CARD and boot from next time on every app u install wud be installed on SD CARD
