Help Phone memory is full
shikem
Member
When I click on settings then wallpaper then gallery to change my wallpaper I get a message that says "not enough memory, delete some items." It also does this when I go straight to the gallery.
I can't delete any items if I can't open the gallery. What can I do short of a factory reset.
Go into the File Manager (I think it's called My Files on a stock Captivate) and delete something.
You managed to fill up the 13.03 gigs of data, huh?
If you don't already have one, purchase an SD card and tell the file manager to move some of your "stuff" to the card. Plenty of expansion available.
Plus, if you noticed one of my other recent posts - http://androidforums.com/151061-titanium-external-sd-card.htmlTitanium and an External SD Card - you can use the SD card for Titanium Backup backups (or MyBackup Pro backups). Nifty way to achieve backup / restore portability in the event you need to warranty exchange your phone or if the phone gets physically damaged in some way.
As YGGDRASIL wrote above, it's called My Files (listed in Applications)
or
Search for EStrongs File Explorer or Astro File Manager, both free from the Market.
