Help Phone never sleeps
gripweed
So I got my new incredible. They over nighted me one because mine won't stop rebooting.
Set everything up last night, check it this morning...
Up Tim 12 hours
Awake Time 11 hours and 50 minutes.
I did all my usual settings, things update every 4 hours or not at all.
I go into apps/running services and WeatherChannel (have a widget on), Astrid Tasks (have a widget on), Messages, Calendar, Google Services Framework, Skype (which I've never signed into), Facebook, News and Weather, Sync Service, and Touch Input have all been awake for the 11 hours and 50 minutes.
The weather channel and astrid I can understand because I got widgets. But Skype and Facebook? Also why is it constantly syncing? It should only sync when I add/change/delete something, right?
Any help?
I do have background data checked in the sync settings. I'd imagine if I turn that off then it'd stop it, but do I have to turn that on everytime I want to use an app or will it just override it when I tell it to sync/update?
I just double checked everything....
Skype I turned off all syncing, I never use it.
Facebook updates every 4 hours.
News and Weather, Auto-Refresh is turned off.
Nope and my battery didn't even lose a bar. Weird.
Anyways, I think I fixed it. I opened up all of those apps and the 'Accept' screens came up and what not, so it seems like maybe they were constantly running until I went in there and logged in and set them up or what not. Who knows.
It's now been running 3 hours longer than it's been awake, so I must of gotten it back to normal.
cool... all else fails install batteryleft, it has a partial wake meter
I've seen this a couple of times. I don't know the cause, but I'm pretty sure that the phone is incorrectly reporting awake time. If your phone really was awake for nearly 12 hours you would have seen significant battery drainage.
I can't remember if I've had to do anything (power cycle or battery pull) to fix it, but I don't think it hasn't ever lasted more than a day.
