I would try it also in the phone settings, not just LauncherPro. I would suggest that you hit the Menu button from the Home Screen, go to "settings", then "Sound and Display", and UNCHECK the Orientation field if it's checked, back out and go back in and recheck it. I've found that sometimes you have to un-set and reset settings like that.
