Help Phone no longer knows its current location
CharlieD
The clock/weather widget seems to no longer know my current location. All it says is literally "Current location". Prior to the 2.2 upgrade and even for a while after the upgrade it used to show the actual city or town I was in. I've played around with the settings under Settings -> Location but nothing makes a difference.
Anyone else seeing this or is there something else I can try?
Thanks.
Mine has been doing that on and off also the last couple of days. It's usually an issue with google and usually resolves itself.
When that's happened to me, it's because my 3G goes to 1x for a bit, or feels like I'm in a bad location, and takes a while to reset itself.
