HTCWiseman
The phone is rooted and thats it, still running stock android 2.2 os
Some of the apps dont load properly anymore (as of today) and widgets say "loading..." and that never changes... The SD card is brand new like 1 month old and sometimes i get the notification that the SD card is faulty and needs formatting... Problem is all my apps are on the SD card so if i format i will have to download and install all the apps again (would be easier to factory reset but I will loose super user etc...)
Is it as simple as getting a new SD card?
