Help phone not found
I am new to android and to this forum but I needed to find some help.
I have the Gt540 and have downloaded all items per the instructions on how to upgrade it to 2.1. However when I connect my phone to the laptop the KDZ updater starts unpacking and then says "phone not found".
I was wondering if this was due to the laptop and would I be better off doing this from a desktop (where USB ports have constant power) or does it matter.
I am running it on AT&T and I am in south Carolina (USA)
Is it something I am doing wrong? I have changed my PC settings so that the USB ports should not be an issue but I don't want to brick my phone...just get it to perform better.
I have read that the update really helps this phone....its pretty slow right now. Please help
Disable LG Modem Driver in Device Manager... Good Luck
tried that. still can't get this to work. Anyone in my area...I will pay you to help me get this done. I have heard of other people paying $30 for this so that is my offer.
If you are near me and are willing to help me upgrade my LG I will pay you for a SUCCESSFUL upgrade.
I don't know if it helps you but i had the same problem in my desktop when i tried to connect my gt540 to the front case usb, when i used the rear ones it worked like a charm, so it might be a power issue.
By the way, don't offer payment in user forums, it's all about helping each other.
Hey Guys Same Problem Here :(
I am a 15 Year Old Boy From India ;)
Damn My Pc's Configration is not good .. 1gb Ram
Same Problem .. "Phone Not Found"
i Love if Android 2.3.4 Would be in my Mobile :) U Genius Might Help Me :)
Thanks Guys :)
Often you may require an update for the OS in your pc. Check windows update for a google fastboot update. I had the same issue and after installing the update it worked fine - I'm running win 7 ultimate. Also disable both LG modem drivers in your device manager so it will pick up the phone itself rather than see it as a modem accessory.
Dude Can you Give Me Link What To Download And What To Install ? i Am Not Getting Your Point .. :) Pls Do 1 Favour.. Give me The Download Link That i Shoud Install :)
My Pc - Running Windows xp
Ram- 1gb
HDD - 160gb
:) Thanx :D
Ram- 1gb
HDD - 160gb
:) Thanx :D
Replied in other thread, please try not to make multiple posts... Thanks
y dont u just use the lg mobile support tool
He's trying to install SwiftDroid...
