Help Phone not recognized by computer, HELP!!
Please help....Im beginning to think I shouldnt have been allowed to buy this phone!
When I connect my phone to the PC it wont register the device as a phone its just showing that a camera has been recognised not a phone. Do I need to get a SD card before the PC will recognise it or does my software on the PC need sorting out? Also how do you get Samsung Kies onto the PC.
Im starting to think I should have stuck with my iphone despite loving the S2. This is driving me mad cus I just cant figure out this problem.
Any advice would be greatly appreciated! (If you can use simple terms, that would be helpful) :)
I tried Kies out but you just dont need it. It's pretty much 'bloatware'.
Go into Settings then Wireless and network then USB utilities then press Connect storage to PC...... and follow the instructions.
You'll need the USB lead handy and a spare USB socket on your PC but it's much easier to connect this way.
I have this same problem. My previous HTC was always recognised by the computer as a storage medium. The S2 only shows up as a GT-I9100 camera. I go to Settings/USB utilities and get "USB mass storage" Tap button below to copy files between the computer and SD card, the button saying Connect storage to PC. I tap and the message is connect USB cable, which I do - all going well so far.
Next screen tells me I have connected via USB. On the computer screen pop up two Removeable Disk icons which, when clicked on, say Please insert a disk into drive X. The button on the G2 screen is Turn on USB storage Clicking that gives no difference to the computer icons, as only a Turn Off USB storage button is there.
I am trying to figure out how to load music onto the thing. I tried it when I had no SD card, and today with a 32Gb Sandisk. Is that the problem? Do I have to format the card? If so, how?
Hoping someone can help.
Do not Plug in your usb before doing these steps
Go into Settings then Wireless and network then USB utilities then press Connect storage to PC, now plug in usb n in few seconds it ll connect. Believe me it works.
Though replying late, may be this information will be usefull for new users facing the same problem.
