tommystery
Hi there,
I've been lurking on these forums for a while waiting for the 2.3.3 update. I haven't done much since using the vanilla LG upgrade since my phone was working well for the most part; recently however it has developed an interesting glitch.
I tried both of your Rom's (Kalendar's .2 alpha and Jiilik .8) and I'd like to thank both of you for the hard work. If I was a developer I'd try to give you guys a hand but I don't have the skills to do so. Jiilik's rom feels much snappier than stock, mainly because of the overclock.
Unfortunately this hasn't fixed my problem...
So here goes: I have recently started to miss calls because some (not all) numbers refuse to ring. I have tried to figure out what might be causing this but have not found a common theme among the numbers (such a specific area code, blocked name or blocked number). What I have noticed however is that the calls also do not show up as "Missed Call" and when I go to my call records the numbers show up as having been picked up with a blue arrow as opposed to the red arrow for the calls which ring.
So far I have tried flashing various ROMs, wiping all the partitions from the phone through recovery, as well as setting different ringtones fro the numbers which aren't working in an effort to override default settings.
I really like this phone but unless this problem gets fixed I won't be able to continue using it. If you guys have any ideas as to what I should be trying I'm up for pretty much anything; I'm thinking that it might have something to do with the radio.img that lg flashed.
Thanks for reading this and Merry Christmas.
