i had the same problem less than a week ago...i came here and was told to download an app called sound manager by daniel roozen. when you open it, if you press menu, it will bring up an option for vibrate settings...the one for notification vibration will be turned all the way off... change that setting to vibrate whenever possible. that should fix your problem
