Hi all,
I have an XPeria Z1 compact (not rooted) that is causing me grief. More and more frequently, the battery starts to drain and the phone starts to become sluggish, and I check the processes and find that the "Phone" process (com.android.phone) is using a lot of CPU. Also using lots of CPU (more than usual) are the Android System process McAffee Security processes.
I can't kill off or reset the Phone process (or else doing so makes no difference), and there doesn't seem to be any way to fix it other than rebooting the phone, though sometimes, unpredictably, the problem resolves itself.
This is driving me crazy. Suggestions as to how to resolve it, or even how to delve deeper into what is causing it, would be much appreciated.
