msierra519
my phone rebooted today twice for no reason..it was on the cradle charging as a listened to music and it turned black and went straight to the sprint screen..anyone have this problem or know why it could be happening?
Were you using Pandora?
gotta do a hard reset, erase everything and start over. wipe cashe etc...
must get msl # and reset your network. i also set my cdma network to automatic. disable kickstand mode and inpocket detection.
Photon is kinda sensitive to certain apps so i would install a few per day and see how it performs. i went a week without a reboot then installed a cracked version of need for speed hot pursuit. it froze a couple times then rebooted...
not that it matters, but does doing a factory reset remove root? i will definitely try the reset later on!
Yes I believe it removes root.
Doing a factory reset does not remove root. I did one yesterday and root remained.
my bad, your right. I did flash the latest SBF yesterday and i did lose root. but its easy to get back. unfortunately im still getting the random reboots.
Here's an interesting fact -- the reboots that I get are not full reboots -- that is, suddenly, it will go to the Sprint Now animated boot screen comes up first. It doesn't fully reboot with the Motorola logo first. The thing is, if you go to the Settings > About Phone > Status and look at system up time, the reboot doesn't show up there!
My phone has been plagued with the same problem. I have had no luck isolating the cause, though I will say that my wife's Photon, which she runs completely stock (maybe half a dozen apps installed, total), is significantly more stable while mine (rooted, dozens of apps) is pretty iffy.
Thats very weird. Mine does a full reboot every single time. Theres an app in the market called reboot logger and it'll keep a record of everytime the phone reboots either randomly or manually.
Purely subjective results from using the "App Cache Cleaner" app mentioned in the Moto support forum thread posted earlier -- it does seem to have helped a little with the reboot problem but I still got a completely random reboot yesterday. Also, it seems to have possibly helped with, but not eliminated, the 'not able to enter text' problem that I also get.
