Help phone rings every 30 mins for no reason
how many times does it ring and does anything on the screen display different, flicker? Is the phone also rooted?
It wont stop ringing and the phone does not flicker. I gotta keep it on vibrate....Im wondering if some program I installed is doing this. I just cant imagine which one.
I have seen and heard it vibrating and beeping on different threads but not ringing. Factory reset generally fixes it if i remember correctly.
Appbrain will not reinstall old programs. I would suggest appmonster or something like it. It will back up your apps to reinstall afterwards, saves having to hunt them down in the market again.
excellent. will do.
what is the point of appbrain?
Appbrain is nice because it gives something different than the market to look at apps, check for updates and get recommendations for more apps off of whats currently on your phone.
