Help Phone rooted but now I have to do a number change Help!!!
Greeting to all,
I have a Metropcs Huawei Ascend M860 it is less than a month old.
I have rooted my phone using steps 1-9 in the all things rooted guide. I have removed all the Metropcs junk ware and left the important stuff as instructed. I have not installed IcarusMOD as of yet I am still trying to get up the nerve to do it. I have replaced the boot screen and that pain in the butt Metropcs Hello startup with my own custom stuff. My phone is a bit laggy and my some apps download but will not install i.e. let
Just unroot it, (i'm assuming you used z4root) and take it to the store to get whatever you need. Then, when it's all done, re-root it. Of course, they might not even need to see your phone to change the number.
I think they only need the 8 digit pin I.E: your birthday as MM.DD.YYYY format... And the code under your battery in the tray... I Might be wrong, though! :D
