Yes, with the phone off. The phone started acting unresponsive in some areas so I did a FDR, and that was a failure. The phone would not boot up after that. After the Droid start up sequence, instead of going to the main screen, the screen would alternate flashing between black and white with a message that the Google app has stopped. I tried 2 more FDR's with the same result. My replacement phone will be here Tuesday.How did you do the Wipe Cache Partition? Starting with a powered-off Turbo?
... Thom
Thanks, and as always thanks for trying to help.Sure sounds like hardware. Good luck with the new one.
... Tholm
